Hey everyone! Got some good news if you’re rocking an Apple TV and also have an iPhone, iPad, or Mac. You can use Apple AirPlay to stream your favorite stuff like shows, movies, music, podcasts, and more right to your Apple TV. Plus, you can mirror your device’s screen on your Mac or Apple TV.
All you need is to make sure your device and Apple TV are on the same Wi-Fi and signed into the same iCloud account. It’s super easy, and here’s how to get started!
Stream or Mirror from a Mac to an Apple TV
Streaming audio from your Mac to your Apple TV is a piece of cake.
Just click the Sound icon in your Mac’s menu bar and pick Apple TV as the destination. When you fire up an audio app, like iTunes, your sound should automatically blast through your Apple TV’s speakers.
For video, just open a streaming app – like the TV app – and click the AirPlay icon, select your Apple TV, and boom, it plays on your TV.
If screen mirroring sounds more like your thing, just hit the Screen Mirroring icon on your Mac’s menu bar. This copies your Mac’s desktop to your TV, so whatever you open on your Mac will show up on the big screen.
How to Screen Mirror from Mac to Apple TV Using JustStream
If you want other ways to use Apple screen mirroring, check out JustStream. This app lets you stream or mirror media content, turning your TV into a second screen. It works with lots of major TV brands like Sony, Samsung, Panasonic, LG, and even with Roku and Apple TV devices.
JustStream is awesome because you don’t need any extra equipment, adapters, or cables – it’s all wireless. The app even has controls to play and pause media from your Mac. After installing it, setting up screen mirroring is super easy. You can even mirror just a single app like Netflix or Apple’s TV app, and you can customize video to fit your TV screen or watch in up to 4K.
How to Mirror Mac to Apple TV via JustStream
Screen mirroring with JustStream is a breeze.
Here’s how:
- Download and install JustStream on your Mac.
- Launch the app and click its icon on your Mac’s menu bar.
- Ensure all devices are on and on the same Wi-Fi.
- Click the Wireless icon at the bottom of the menu (a device is selected by default).
- Pick the device you want to mirror from the Screens list.
- Add the file you want to display and click Start Streaming.
- For audio, install the JustStream Audio Driver (comes with the installer). Enable desktop sound transmission and microphone access.
- To stop mirroring, just hit Stop Streaming.
How to Set Up AirPlay on Your Apple TV
Skipping JustStream and want to stick with AirPlay? Here’s how to set up screen mirroring from iPhone to Apple TV:
- Turn on your Apple TV and go to Settings > AirPlay and HomeKit. Make sure AirPlay is on.
- Set security measures by selecting Allow Access and choosing the access type.
Choose Everyone to let anyone stream/mirror or Anyone on the Same Network for just those on your Wi-Fi. Only People Sharing This Home restricts it to your Apple Family.
You can also set an optional AirPlay password, but your Wi-Fi should already be protected.
How to Set Up AirPlay on Your Mac
Wondering how to get AirPlay going on your Mac? Here’s the drill:
- Turn on your Mac and go to System Preferences > Sharing.
- Make sure the box for AirPlay Receiver is checked.
Choose to allow AirPlay for the current user, anyone on the same Wi-Fi, or everyone.
Set a password if you like.
AirPlay Compatibility
AirPlay 2, launched in 2018, brought more features and better performance. It works with nearly all iPhone models from 5S and SE to the current iPhone 13. It supports all iPads from the iPad Mini 2 up. Also, it works with the latest iPod Touch models.
For receivers, AirPlay 2 supports Apple TV 4K or HD with tvOS 11.4 or later, and many smart TVs from top brands. If you have a 2nd or 3rd-gen Apple TV, you’ll need the original AirPlay.
If Apple TV Is Not Screen Mirroring
If you’re having trouble with Apple TV screen mirroring, here are some tips to fix the issues:
- Make sure both the AirPlay device and Apple TV are on and connected to the same Wi-Fi.
- Try toggling Bluetooth on and off on your iOS device. Go to your Settings and reset if needed.
If you have any more questions or need help, feel free to ask here!
## Having Issues with Apple TV Screen Mirroring? Let’s Fix That!
Hey folks! If you’re struggling to get your Apple TV screen mirroring to work, don’t worry, you’re not alone. Here’s a quick checklist that can help you troubleshoot and (hopefully) solve the problem.
Bluetooth Troubleshooting
First things first, let’s tackle Bluetooth:
- Try flipping Bluetooth off and on again.
- Go to Control Center or head to Settings > General > Bluetooth.
Wi-Fi Troubleshooting
If Bluetooth seems fine, let’s move on to Wi-Fi:
- Try toggling Wi-Fi off and on again.
- On your iOS device, go to the Control Center or Settings > General > Wi-Fi.
Firmware and Software Updates
- Make sure your Wi-Fi router is up-to-date.
- Double-check that your Apple TV has the latest software.
- Go to Settings > General > Update Software.
- Your iOS device should also be updated.
- Go to Settings > General > Software Update to check for any new updates.
Reboot Everything
Sometimes, a good old restart does wonders:
- Reboot your Wi-Fi router, Apple TV, or any other AirPlay device.
- Restart your iOS device.
- Hold the Side button with either Volume button, then slide to power off.
- Make sure only one device is streaming at a time.
Third-Party Apps and Privacy Restrictions
- Some third-party apps like AirParrot or Duet might interfere with AirPlay. Try uninstalling these.
- Disable content and privacy restrictions.
- Head to Settings > Screen Time > Content & Privacy Restrictions.
Still Having Trouble?
If none of these steps worked, you might need to look at your Mac’s settings.
Fixing AirPlay on Your Mac
Step-by-Step Guide
Step 1: Check Firewall Settings
- Go to System Preferences > Security & Privacy > Firewall.
- Click the padlock, enter your admin password, then open Firewall Options.
- Make sure Block all incoming connections isn’t turned on.
- Tick the box to Automatically allow built-in software to receive incoming connections.
Step 2: Reset Your Mac
- Hold down the Power button to shut down your Mac.
- While restarting, hold Option + Command + P + R for about 20 seconds until you hear a startup chime. This will reset some temporary settings like display resolution, startup disk, and volume.
Hopefully, these steps help you get your Apple TV screen mirroring working again! If you’ve got any more tips or need further help, drop a comment below!
