iPads use AirPlay while Chromecast uses Google Cast, making direct connection impossible. You can mirror your iPad to Chromecast using the DoCast app, which streams photos, videos, and DRM-free music. Follow these steps: download and install DoCast, connect both devices to the same network, select your Chromecast, and start mirroring. Beware that the free version limits sessions to 15 minutes. Replicate can help cast photos and videos too. Built-in casting apps include Netflix, Hulu, and Spotify. If you face issues, check network connectivity, device software, and app compatibility. Stay tuned for a more detailed tutorial in our next forum post!
Hey everyone!
Just wanted to share some tips on how to use AirPlay and Google Cast with iPads and Chromecast devices. Unfortunately, you can’t directly connect your iPad to Chromecast because they use different protocols. But don’t worry, there’s a workaround! Read on to find out how to watch content from your iPad on your TV using Chromecast.
How to Screen Mirror iPad to Chromecast with DoCast
Here’s a simple way to use DoCast to stream your media:
If you’re looking to cast stuff from your iPad, DoCast is a great app. It lets you stream pics, vids, and DRM-free music from your device. Plus, you can mirror your screen for apps that don’t support casting!
Steps to Chromecast from iPad Using DoCast:
Download the DoCast Chromecast app for iPad and open it up.
Make sure your iPad is on the same network as the Chromecast.
Your Chromecast should show up in the app. Tap on it to connect.
Tap Screen.
Choose your orientation, quality, and whether to keep the mic on.
Tap Start mirroring.
You can even cast photos and videos directly from your iPad’s library using the Photos and Videos options in DoCast. Cool, right?
NOTE: The free version limits each mirroring session to 15 minutes, so keep that in mind.
Be aware that apps like Netflix, Hulu, and HBO Max might not work due to copyright restrictions, which is kinda understandable.
What Apps Have Built-in Cast Icons?
For those who love streaming, apps like YouTube, Netflix, Hulu, Prime Video, Disney+, and HBO Max make it super easy. Just open the app, play your video, tap the Cast icon, and select your Chromecast.
You can also stream music from apps like Spotify and Amazon Music. Simply open the app, play a song, tap on the device option, and select your Chromecast!
How Do I Cast Other Content from My iPad?
Screen mirroring and built-in cast features aren’t the only ways to enjoy your iPad’s content on the big screen. You can also cast photos and videos directly from your gallery.
How to Cast a Photo or Video from Your iPad
Use Replica! This app lets you Chromecast media in HD, and it works with other devices like Amazon Fire TV, Android TVs, and even PlayStations.
Here’s how to do it:
Step 1: Download the Replica app on your iPad and fire it up once it’s downloaded.
Step 2: Make sure your iPad and Chromecast are on the same Wi-Fi network. This is crucial!
Step 3: The Replica app should detect your Chromecast. Just tap on it to connect.
Step 4: Tap on Gallery.
Step 5: Pick your photos or videos from the gallery, and they’ll show up on your TV.
NOTE: Replica lets you cast for up to 15 minutes for free per session.
There’s also a built-in browser in Replica for casting web videos by tapping on Web Videos. If you choose the Camera option, you can display whatever your camera sees on your TV.
Troubleshooting Common Issues
Running into some hiccups when trying to cast? Here are a few common issues and fixes:
- Different Networks: Make sure your iPad and Chromecast are on the same Wi-Fi network.
- Temporary Software Glitch: Sometimes a quick restart of your iPad or Chromecast can do the trick.
- Outdated Software: If the app is outdated, it might not work with your Chromecast. Keep all software up to date.
- Wrong App: Not all casting apps support Google Cast. Ensure the app mentions Chromecast compatibility.
- Signal Problems: Ensure your router is within range (about 100 to 150 feet). Signal interference from walls or other devices can also be an issue.
Final Thoughts
Remember, Chromecast devices work as Google Cast receivers. That means you can’t stream directly from an iPad, which uses AirPlay. If you’re in need of a screencast and mirroring app, DoCast is a solid choice.
You can start mirroring in HD with just a few taps, and even the free version offers generous casting time. So whether you’ve got an iPad Mini or an iPad Air, you can easily cast your photos and videos from your iPad to Google Chromecast and enjoy them on the big screen!
Cheers, and happy casting!
