Roku devices let you watch streaming services on your TV, and you can screen mirror from your smartphone or Mac. We discuss four top apps for Mac-to-Roku mirroring: JustStream, AirBeamTV, Mirror for Roku, and LetsView. You can also use AirPlay on compatible Roku models. Key steps to screen mirroring from Android and Windows devices are outlined. Stay tuned for our next forum post, where we’ll dive into more detailed tutorials for these methods.
Hey everyone!
So, I wanted to share some tips on how to watch shows and movies from all your fave streaming services on your TV using Roku. With a Roku device, you can browse through different channels on their app and select what you wanna watch. But what if you wanna screen mirror your computer or smartphone to Roku?
In this post, I’ll show you how easy it is to cast or mirror your smartphone or Mac to Roku. And I’ll cover the best ways to mirror Mac to Roku. Ready? Let’s dive in!
The Best Ways to Mirror Mac to Roku
1. JustStream
First up, JustStream. This app is super handy for casting or screen mirroring your MacBook to Roku. You can choose the image quality you want - HD 720p or Full HD 1080p. Cool, right?
Here’s how you do it:
- Download the JustStream app from the Mac App Store and install it on your Mac.
- Launch the app.
- Click the mirror icon in the menu bar, then select your Roku TV to start mirroring. Easy peasy!
2. AirBeamTV
Next up is AirBeamTV. This one’s great for wirelessly mirroring your MacBook screen to your TV. You can watch videos, view photos, and even use apps on your smart TV with this app!
Here’s how to use AirBeamTV:
- Download the AirBeamTV app on your MacBook Pro or MacBook Air.
- Launch the app and start mirroring from your laptop.
- You’ll see your whole MacBook screen on your TV! How cool is that?
3. Mirror for Roku
Last but not least, Mirror for Roku. This app is designed for TVs without a built-in Roku, so you can use it with almost any TV. No smart TV or Apple TV is needed.
Here’s how to get started with Mirror for Roku:
- Download the Mirror for Roku app on your Mac.
- Launch the app, then wait for it to discover your Roku TV device.
- Once your device is discovered, tap the name of your Airbeam TV app for Roku.
- Boom! Your Mac screen is now being mirrored to your TV.
Give these a try and let me know how it goes!
Let’s Talk About LetsView for Mac
Hey guys, if you’re looking for an intuitive way to mirror your Mac screen to your TV, you should totally check out LetsView! It’s super easy to use and perfect for catching up on videos, browsing photos, or displaying files on the big screen. Here’s where you can get it.
How to Use LetsView for Mac:
- Download and Install: Get LetsView on both your Mac and your TV.
- Launch the App: Open LetsView on both devices.
- Enter PIN Code: On your Mac, input the PIN that shows up on your TV.
- Start Mirroring: Bam! Your Mac screen should now appear on your TV.
AirPlay on Roku
Yep, there’s another way to enjoy your Mac content on your TV – by using AirPlay. Below we’ve covered how you can stream via AirPlay and the models that support it.
Roku Models That Support AirPlay
Here’s a quick list of Roku models that support AirPlay:
Need to run Roku OS 9.4 or higher:
- Roku TV models: Axxxx, Cxxxx, CxxGB, and 7xxxx
- Roku Streambar & Streambar Pro
- Roku Smart Soundbar: 9100 and 9101
- Roku Streaming Stick+: 3810 and 3811
- Roku Streaming Stick 4K and 4K+: 3820, 3821
- Roku Express 4K and 4K+: 3940, 3941
- Roku Premiere: 3920, 4620
- Roku Premiere+: 3921, 4630
- Roku Ultra: 4600, 4640, 4660, 4661, 4670, 4800
- Roku Ultra LT: 4662, 4801
Need to run Roku OS 10.0 or higher:
- Roku TV model: Dxxxx, 8xxxx
- Roku Streaming Stick: 3600, 3800, 3801
- Roku Express: 3900, 3930
- Roku Express+: 3910, 3931
- Roku HD: 3932
- Roku 2: 4205, 4210
- Roku 3: 4200, 4201, 4230
Quick tip: To find out your Roku model, go to the Roku home screen > Settings > System > About.
Note: Your Apple device must support AirPlay. Devices like iPhones, iPads, iPod Touch running iOS 12.3+, or Macs with macOS Mojave 10.14.5+ are compatible.
Casting vs. Mirroring: What’s the Difference?
You might hear ‘casting’ and ‘mirroring’ thrown around, but what’s the difference? Let’s break it down:
Casting: This sends specific content from a mobile app to your TV. While casting, your phone is free for other things like checking messages. Playback continues even if you turn off your phone.
Screen Mirroring: This shows your entire mobile device’s screen on your TV. You see everything—the whole shebang. Mirroring doesn’t use your Roku remote for control; it’s all done through your phone.
More Solutions
Want to mirror your Android or Windows device to Roku? We’ve got you covered. Read on for the deets!
Mirror Android to Roku
You can mirror your Android phone or tablet to Roku if your devices support it. Rokus after 2017 and Android devices with version 4.2+ usually do. Check your device documentation to be sure.
Steps to Mirror Android to Roku:
- Update: Ensure both devices are up-to-date.
- Check Naming: Screen mirroring might have different names (AllShare Cast, Smart View, etc.) depending on your phone.
- Enable Mirroring: Go to settings on your Android, find the mirroring option, and enable it.
- Set up on Roku: Go to Roku Settings > System > Screen mirroring and check “enable screen mirroring.”
- Connect: Select your Roku from the device list to set up the connection.
- Done! You should be mirroring now.
Mirror Windows to Roku
Got a Windows PC with Miracast? You’re good to go. Here’s how you can mirror from a Windows PC to Roku.
Steps for Windows 8.1 Users to Mirror:
- Power Up: Turn on your Roku.
- Go to Settings: Roku Settings > System > Screen mirroring.
- Enable: Ensure “Enable screen mirroring” is checked.
- Windows Shortcut: Hold Windows + C keys, then select Devices > Project.
- Add Display: Click “Add a wireless display” and pick your Roku from the list.
Wrap-Up
Hope this guide helps you find the best way to mirror your Mac screen to Roku or any other TV. Whether you’re using LetsView, AirPlay, or other methods, there’s a way to get your screen up on the big one. Happy mirroring!
