Best Solutions to Mirror iPhone to Firestick in 2024
Amazon’s Firestick offers a wide range of streaming content, but it doesn’t support AirPlay for iPhone mirroring. To screen mirror an iPhone to a Firestick, third-party apps like DoCast, Screen Mirroring・Smart View TV, AirScreen, Replica, SmartTV Cast, and TV Cast & Screen Mirroring App are required. Each app has its pros and cons, with DoCast rated the highest for its usability and ad-free experience. Ensure both devices are connected to the same Wi-Fi network and follow specific steps for each app. Stay tuned for a detailed tutorial in the next forum post.
Amazon’s Firestick is your go-to gadget for streaming. Just plug it into your TV and enjoy endless entertainment. But bummer, it doesn’t support AirPlay. So, if you wanna mirror your iPhone screen on that big TV, you’ll need some third-party apps. Don’t sweat it; we’ve done the legwork and tested a bunch for you. Let’s check them out so you can binge-watch your favorites on the big screen!
How to Mirror iPhone to Firestick :iphone::arrow_right::tv:
Before diving in, here are some quick prep steps to avoid headaches:
  1. Wi-Fi Check: Make sure your iPhone and Firestick are on the same Wi-Fi network.
  2. Update Firestick: Ensure your Firestick has the latest updates.
  3. Compatibility: Some apps don’t jive with Firestick Lite. Double-check before you start.
Now, let’s get into the juicy details of our recommended apps!
:1st_place_medal: DoCast
When it comes to mirroring your iPhone to Firestick, DoCast is top-notch. It’s super easy—just download it on your iPhone, no need for an app on Firestick.
Free Version: Screen mirroring lasts 15 minutes per session, but you can tweak video quality and enable auto-rotation.
How to Use DoCast:
  1. Download: Grab DoCast from the App Store.
  2. Connect: Open the app and let it find your Firestick (same Wi-Fi!).
  3. Select Device: Tap your Firestick when it pops up.
  4. Mirror Screen: Head to the main menu and tap Screen.
  5. Adjust Settings: Set preferences and tap the red button.
  6. Start Broadcast: Hit Start Broadcast to begin mirroring.
  • No Firestick app needed.
  • Ad-free.
  • Unlimited photo casting.
  • Quick setup.
  • 7-day trial version.
  • Free version limits mirroring to 15 minutes/session.
:star: Our rating: 5.0/5
:2nd_place_medal: Screen Mirroring・Smart View TV
Another solid choice is Screen Mirroring・Smart View TV. This app is versatile—you can mirror your iPhone, cast videos, stream photos, and even watch IPTV if you go premium. Gamers will love the zero-latency feature.
How to Use:
  1. Download: Get Screen Mirroring・Smart View TV.
  2. Connect: Tap the casting icon and select your Firestick.
  3. Tap Screen Mirroring: Select Screen Mirroring in the main menu.
  4. Start Mirroring: Adjust the settings and tap the red button.
  • Supports AirScreen, so works with all Firestick models.
  • Premium version supports offline and online casting.
  • Adjustable screen resolution.
  • Online casting needs a premium subscription.
:star: Our rating: 4.0/5
:3rd_place_medal: AirScreen
AirScreen is a well-known name in the Firestick community. It’s a lifesaver if you have a Firestick or Fire TV that’s not compatible with AirPlay. No iPhone app needed—just download it on your Firestick.
How to Use AirScreen:
  1. Download: Install AirScreen from the Fire Stick app store or the Amazon site.
  2. Scan QR Code: When you open AirScreen, scan the QR code with your iPhone.
  3. Follow Instructions: You’ll be directed to a site with step-by-step instructions.
  4. Connect: Ensure AirScreen is on the home screen on Firestick. Find the AirPlay receiver’s name.
  5. Screen Mirroring: Open Control Center on your iPhone, tap Screen Mirroring, and select the AirScreen receiver.
  • Supports many third-party apps and Apple devices.
  • Free to use.
  • No iPhone app needed.
  • Ads start showing up in the free version.
  • Can be glitchy at times.
:star: Our rating: 3.5/5
4. Replica
So, what’s the deal with Replica? It’s a go-to app for streaming via Chromecast but works just as fabulously on FireStick. Quick heads up, though - you’ll need a companion app for screen mirroring to fly.
Replica lets you mirror your screen and cast content, whether you’re offline or online. While there’s a lot to love about it, having to download apps on both devices and dealing with ads can be a total mood kill for some.
Here’s a quick rundown of how it works:
  1. Download Replica on your iPhone from the App Store.
  2. Launch the app and pick your FireStick to connect.
  3. You’ll need to download Replica’s companion app on your FireStick from the Amazon app store.
  4. Open Replica on your iPhone and head to the main dashboard.
  5. Tap Screen Mirroring.
  6. Finally, select Start Broadcast to kick off the mirroring session.
  • Super minimal interface
  • Supports casting of both offline and online content
  • Offers a 3-day trial
  • Too many ads
  • Needs a companion app on FireStick
Rating: 3.8/5 :star:
5. SmartTV Cast: Screen Mirroring
Next up is SmartTV Cast: Screen Mirroring, which supports all sorts of TV brands like Samsung, Panasonic, and FireStick. It has all the bells and whistles, including screen mirroring, casting, a built-in web browser, and a remote TV feature.
However, you’ll need to upgrade to premium to mirror your iPhone to your FireStick. No free lunch here, folks.
Here’s how to start mirroring (assuming you’ve splurged on the premium version):
  1. Download SmartTV Cast on your iPhone from the App Store.
  2. Open it up and choose Fire TV as your streaming device.
  3. Pick your FireStick to connect.
  4. Hit Mirror Screen at the bottom.
  5. Tap Start Mirroring and then Start Broadcast.
  • Works with multiple TV brands and devices
  • Can be used as a remote control for TVs
  • Casts any file type
  • Requires a premium subscription for screen mirroring
Rating: 3.0/5 :star:
:tada: 6. TV Cast & Screen Mirroring App
TV Cast & Screen Mirroring supports a wide variety of TV brands and streaming gadgets. It’s got some pretty nifty features, though the frequent unskippable ads can be a bit much.
You can cast photos, videos, music, and even YouTube videos with this app. Note: You’ll need to go premium for the screen mirroring feature.
Here’s how you can use it:
  1. Download TV Cast & Screen Mirroring from the App Store on your iPhone.
  2. Open the app and connect to your FireStick.
  3. Tap Quality Screen Mirroring.
  4. Press the record button.
  5. Select Start Broadcast, and your iPhone’s screen will appear on your Fire Stick in moments.
  • Casts photos, music, and videos
  • Supports direct casting from YouTube
  • Too many ads
Rating: 2.5/5 :star:
How to Choose the Perfect App :thinking:
Picking the right app for mirroring your iPhone to your Fire Stick can be tricky. Here are some things to think about:
  • Compatibility – Make sure it works with your Fire Stick and iPhone model.
  • Convenience – Go for a user-friendly app without too many ads.
  • Free version limits – Check if the free version has annoying ads or paywalls.
  • Bonus features – Need extras like casting offline photos or videos? Find an app that has them.
  • User reviews – It helps to know what other users think, so read some reviews!
Conclusion
There are plenty of options for mirroring your iPhone’s screen to a Fire Stick, but the best pick depends on your needs. Focus on bonus features, user-friendliness, and compatibility.
After trying many apps, we’ve found DoCast to be the top choice for mirroring iPhone to FireStick. It’s free and ad-free. Just download it on your iPhone, and you’re good to go!
You can get more info here.
Happy mirroring! :blush:
